I am currently building a 350 sb and looking for guidance on rear seal installation (1piece). The installation documentation with Fel-Pro does not go into much detail. Any help will be appreciated!
1) I assume the open side showing the spring faces in towards the block.
2) Should I use sealant on the OD of the seal and bearing cap?
3) Pretty sure I need to apply grease to the sealing surface?
