My 68, 327 with headers, Camaro has a small rear main seal leak. Is this a hard fix? Does motor have to be pulled?
Most leaks that appear to be from the rear main seal are actually higher up,..rear of the valve covers, rear of the intake, distributor gasket, oil filter, oil pressure sending unit, etc.
All the above will eventually drip from the bottom of the engine and/or bellhousing.
Do this,..purchase the dye kit and make sure you're chasing the correct leak.
Good luck!
