I have what i believe to be a may 14 69 camaro rear that is stamped pg.I cant find that listed anywhere in 10 bolt listings.Its a 10 bolt casting#3894859 NF, GM 55,casting date E 6 9,co 1, tube#s PG0514G2 Thanks for any info.Guy.
Thanks when i rotated the wheel thats what the ratio came out to but I could`nt find pg anywhere.Thanks again.Guy.
Go to www.camaros.org you will find it there in the drive train decode. That is were I found it. Scroll down to the axle codes. The 69's are on the right side columns, the PG is on the left side and follow it over under the 69 model year.
