well it helps if you can bench press 485lbs.....theyre hard to do sometimes
I do one side at a time about a foot from the side grab the bottom edge both hands palms up push in hard for about an inch and a half then up a bit and let it back out then do the other side the same way.
For a good pic of the latch see this thread http://www.camaros.net/forums/showthread.php?t=97714
I find it helpful to use your whole body. So rather than try to push from outside the vehicle leaning in, I slide my front seats all the way forward and crouch down in front of the rear seat and push with my legs/body.
But everyone else pretty much covered it. Push back up and pull out, one side at a time. Sort of like a U motion...
After reading this thread I was successful in taking out my back seat this weekend. Knowledge is power, it was definitely easier knowing the tricks of the trade.
BTW, I had to take it out because my seat belts were tucked under the seat.
:beers: to you guys for being so helpful
-Boo
