1 - 16 of 16 Posts
Hello!
I'm new to this forum, have owned a -67 Camaro for 16 years now
I'm replacing the old monoleaf springs to Hotchkis 1.5" drop multileafs and putting new Energy Suspension bushings
- The problem is rear frame bushings. Even when the bushings are installed all the way in to the rear frame hole, the sleeve is not flush with the bushing ends. The sleeve is a good 0.15” too short.
- So, basically the rear frame hole is 0.15" too wide for the bushings and the sleeve. And since the sleeve is not flush with the bushings, the shackle causes extra stress to the bushing ends because it doesn't bottom out to the sleeve
- Another side-effect is that the shackles are not parallel since the width of the frame hole is 0.15" more than the leaf spring rear eye
Anyone else noticed this and done something about it? I'm thinking of grinding 0.075 per side of the frame hole...
I would assume this could be one of the things that can cause squealing...
Any help greatly appreciated!
Best regards,
Pasi
Discussion Starter #2
Attached is a rude and crude illustration of what I mean in my previous post. Hopefully it clarifies the issue with the rear shackle frame bushing
So 1st gen and 2nd gen Camaro bushings are different. The 2nd gen has a larger lip. Could you have mismatched bushings? Has your frame rails been replaced?
Kevin,
Appreciate the quick reply!
Both the rear spring eye bushings and the frame bushings are identical. My old ES bushings that I removed were exactly the same.
No, my frame rails or anything related to that are stock, they have not been replaced or modified.
Now that you said that 1gen and 2gen are different... I have Energy Suspension Part# 3.2135G kit...In the ES website it says it's compatible with -67 Camaro but also lists compatible models from 67 to 81 for that! So from 1gen to 2gen.
In comparison, Energy Suspension Part# 3.2137G lists only 67 to 69 as compatible. So it seems there's a ES compatibility F***up in their website...I'm going to order Part# 3.2137G first and see if that corrects the issue
Thanks,
Pasi
Crap.
I was a bit too quick in my web searches. Energy Suspension Part# 3.2137G is for monoleaf...
It would be nice to know how much different the 1gen and 2gen rear frame bushings dimensions are...I guess ES sells one type that's "good enough" for both gens.
BR,
Pasi
Hey Pasi, just saw you are from Finland, cool. Good friends of mine are from Finland, we hope to join them on one of their trips back home :)
Measure your bushings, total length and length from inner edge (where it is supposed to fit in hole). I can compare to my stock GM ones when I get home.
Didn't the shackle kit and new bushings come with the Hotchkis leafs ?? I just installed mine last week or so. Why use ES bushings ?? I used the Hotchkis supplied bushings. No problems.
Discussion Starter #8
Kevin,
It's a small world right! :smile2:
Here are my measurements :
- Bushing total length : About 1.48"
- Bushing length, part that goes inside the hole : 1.2"
- Sleeve length : 3"
- Leaf spring rear eye length : About 2.46"
- Framerail hole length : About 2.61"
And in a nutshell
- Bushings and sleeves are identical both rear spring eye and framerail hole
- Sleeves are perfectly flush with the bushings in the rear spring eye, but not in the framerail hole
So since the framerail hole is about 0.150" longer than the spring eye, the same size bushings end up being that much longer in the framerail hole than the spring eye
And since the sleeve is only 3" long it's not flush with the bushings in the framerail hole
DT : I used the Hotchkis supplied shackle kit and they are in fact ES bushings and identical to my old ES poly bushings. I just replaced the front spring eye bushing from stock to ES. If you still have the plastic bag that contained the bushings there's a part# (9.9506G) and that's an ES part#. It's just a rather special one, probably because Hotchkis is their customer
Best regards,
Pasi
OK judging by your pics here: cammm67's Library | Photobucket
You are using poly bushings. I don't have that much experience with polys.
But I pulled out some new rubber ones.
So when you put your bushings together it works like this:
total end to end 2.96" This makes sense that the sleeve is 3"
total inside 2.4" OK for spring, but too short for frame
Rubber bushings (remember there is some crush factor for them unlike polys)
total end to end 3 1/2" (1/4" to 3/8" of lip)
total inside between 2 5/8" and 2 3/4" this would fit both the frame and the spring
So I would say the poly bushings inside measurement is too short.
Discussion Starter #11
OK,
Didn't get help from Hotchkis nor ES...
So, I did the hilarious solution, I whipped 2 longer bushings on a lathe and modified the shackles.
Being in the metric part of the world, it meant cutting a 20mm OD - 14mm ID tube to 3/4" OD - 9/16" ID
That solved the "bushing too short"-issue. But still the shackles were not parallel since the framerail hole is 0.15" longer
So I welded two 0.075" stainless steel plates to the shackles, to "widen" the leaf spring eye part
Not really the easiest solution but it worked great
ORIGINAL SLEEVE AND 2 NEW LONGER SLEEVES :
MODIFIED SHACKLES WITH SLEEVES :
I'd say that looks great! I think most of us would've used a washer, though... Much easier.
Hmmm, I'm pretty sure my shackles are cadmium in color. Perhaps they changed shackles. Nice job btw.
Looks like the original spacers would work if you flipped the shackles so the welded tabs on the inside were to the outside?
Discussion Starter #16
Me too! Yes I tried to find a suitable washer but didn't find any, so had to do the "next best thing"
DT : Those were the same color like yours, I just painted those black cos they took a beating when welding
1 - 16 of 16 Posts
