1 - 1 of 1 Posts
Do they mount correctly if the rear axle housing has been lifted 2"?
From what I gather they mount to axle housing with large U bolts then end links that are mounted to braces bolted to rear sub-frame
The axle housing would be closer to the rear sub frame since it is lifted with the blocks
So do rear sway bars mount if using lowering blocks on top of leaf springs??
1 - 1 of 1 Posts
