I have a new rear tail light wiring harness and when I insert the tail light housing it sparks. 1157s are installed correctly so I think it’s a ground issue. Wiring diagram doesn’t show how the system is grounded and I followed back to under the dash and didn’t see any grounds. The brake switch is out so Im not sure if the system is grounded through it. New switch was ordered. Any thoughts?
