1 - 2 of 2 Posts
I am testing the wiring job I have done on my 69 350. After installing new harnesses bumper to bumper, the only problem I have encounted is that the rear turn signal bulbs are constantly lighted. They flash properly when the signal lever is engaged right or left, and they remain lighted when the headlights are on. Could this be a problem with the headlight switch? Or possibly a grounding problem? I believe those bulbs also serve as the rear "park lights" on this car. DP
Check to see if your stop light switch is
adjusted properly. If it's not your brake
lights will stay on.
Bob
1 - 2 of 2 Posts
