Hey all,
I have installed Ride Tech's 4-link rear suspension in my '69 camaro. I mocked everything up last week to tack-weld the Ride-Tech brackets tot the top of the rear axle housing. When I did the tack welds, I made sure the car was at ride height, the pinion angle was set and that the wheels were centered within the frame of the car. After tacking the brackets in place, i took the axle out and brought it to a real welder to finish the job. Today, I am mocking everything up again before I bring the housing to powder coat. I am seeing that the driver's side wheel is about 1/4 inch farther to the left when compared to the passenger side wheel.
Is there an adjustment to this that I am unaware of?
If not, is 1/4" off center acceptable?
Thanks for any input.
