1 - 2 of 2 Posts
I have a 67 camaro
2" lower coil spring in front (hotchkis)
3 inch lower leaf springs in back (hotchkis)
everything else is stock--not mini tubed
the look im going for is larger rim with smaller low profile tire
with no rubbing
yes i read the 67 camaro post however i did not see anything that matched my specs. tire and rim combos are expensive and need to get it right the first time.
18 x 9.5 with 5.5 backspacing and 275 35 rear
18 x 8 with 5.25 backspacing and 235 40 front
i myself am running 18 x 9.5 with 5.5 backspacing and 275 35 on all four corners with tru turn system, and hotchkiss uca and hotchkiss 2" drop 600lb coils. Front fender wells slightly modded of course.
1 - 2 of 2 Posts
