1 - 10 of 10 Posts
Tomorrow I'm pulling all my March serpentine kit pulleys, belt, alt and A/C compressor off. The A/C has never worked since I've had the car; not sure why, whether for lack of the system ever being charged, wiring or what.
But when taking off the compressor, if there is freon in the system, will it go spraying out everywhere when I remove hoses or what will happen?
I have no idea what the effect of escaping freon is -- or even if it's going to be a problem for me, as I don't know if there's freon in the system -- so if this is a stupid question, sorry.
Also (and I know this is the wrong forum for this, but) I'm removing the remote power steering reservoir and pump as well. Do I need to drain it first, or will it stay contained in the reservoir?
I'm not an a/c expert but if the system is charged it needs to be evacuated and the freon recovered. You will loose oil from the system as well if you release the freon. You can tell if its charged by putting on a set of gauges if you have them. Does the compressor engage when the system is switched on? You should hear a click and the clutch on the front of the compressor should engage when you turn on the a/c.
Discussion Starter · #3 ·
Crap... I don't know if the compressor engages, b/c when I "fixed" all the wiring (rerouting it from laying all over the wheel wells), I never got all the wiring reconnected properly. So when I flip on the fan switch on the dash, nothing happens, at all. I know that's just my inability to reconnect everything properly and nothing to do with the A/C, per se.
However, when the fan was wired, before I jacked with it (fan would blow hot air, but not A/C) no, I never got the A/C clicking-on sound, just fans blowing... A while back though, I started to move one of the hoses that runs from the compressor to somewhere in the firewall (don't know which/what hose it was), I heard a very noticeable "hiissss" sound, so I immediately re-tightened the clamp and haven't jacked with it since.
That probably doesn't help much, huh? :eek:
You have 3 choices. Recover it as Larry mentioned. Leave the compressor in place. Or vent it to the atmosphere and destroy the ozone which will kill everything on planet earth.
What is your intentions with the A/C? If you want it to work then get a schematic and start trouble shooting, because it sounds like you have electrical issues.
Discussion Starter · #5 ·
Recovering it sounds like the better choice of the 3.
I'm selling my March serpentine kit, so the A/C compressor goes with the set up. I know you're right, for certain about the electrical issues. As I mentioned above, I rerouted a bunch of the A/C wiring a while back and clearly just never got it re-wired correctly.
Banned
l:)
I changed a compressor out on a 95 escort and simply re-charged the system with a refill kit.
But don't tell Al Gore.
Discussion Starter · #8 ·
After I did some research, all I'm going to say is it got done the old fashioned way.
Now I gotta get to work cleaning up the block. Disgusting huh!? Thinking pressure wash (if I can shove it out of the garage), degreasers, scotch bright pads and mineral spirits???
I know it just takes elbow grease, but recommendations are appreciated!
1 - 10 of 10 Posts
