I have 17 inch rims . And the crome is starting to chip off. I would like to strip them and have them power coated white. I took them to a shop in nj that power coats. The guy sand blasted one rim. He got the crome off, but also ate grooves in the rim. Any one know a better way to remove the crome? I don't trust letting this guy sand blast my other 3 rims.They are aluminum under the crome.Can they be asid bath to remove? Thank for any info mike s.
Mike,
Aircraft paint remover might do it, it's safe for aluminum but I don't know if it would strip the chrome off. Wouldn't hurt to try.
Robert
68 Base Coupe, 327/210hp with TH400
99 Silverado 5.3L
I own a powdercoating shop in New york.
If the guy sandblasted your rims and left groovesthats ok.Powdercoat will definately fillin those voids.And any oyher imperfection that the rims may have.Good luck
I asked around about the same thing a few years ago (I wanted a grill "dechromed")....The best answer that I got was to send them to a chrome plating shop and have them "unplated"....I guess it's some kind of reverse plating procedure.....
