I have bee able to get the pulley off of the power steering pump but how do I get the key or chuck out of the power steering pump shaft? Any tips greatly appreciated!
most likely its rusted or very tight fit. try a pointed punch near the shaft to see if you can tap it out. i'am sure its not machined in, too expensive and time consuming.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[email protected] W/ 2.73POSI.
Try a brass punch and punch down on the rear of the key. It's half round and the front should lift up when you do that. Then pry or punch up the front end of the key and lift out.
If you are changing the seal, you may need a tool to guide the seal over the shaft sholder or it will turn the seal lip inside out and damage it.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350 Can-Am Vintage Racer
Thanks, the tips worked. I was able to get the front of the key lifted up a bit with a punch and then used a chisel and a few light taps to get it out. I needed to transfer it to the new pump, so used the bench vice to "press" it into the new shaft.
