Need some serious advice, I'm in the middle of removing my outter wheel wells, I have drilled out all the spot weld and still can not get the wheel well to move. What do I do? I dont want to damage anything around it. but do I need to start using a hammer?
there is usually sealant where the 2 (inner and outer)wheel wells join,sometimes you have to run a narrow cold chisel up between the wheel wells by the spot welds just incase part of the welds are still holding.-Harvey
