I would like some opinions on what this engine might sell for.The engine is carb to pan less headers.It is installed in my 68 Camaro and can be started and driven.It has 2000 miles on a rebuild.No noises and good power and oil pressure.I need to sell this engine to finance my blown stroker project upcoming.Thanks.
.030 over 427 BBC
Casting #3963512
4 bolt main.Forged crank. .030 under mains and rods
Clevite 77,s
HV oil pump
resized 454 rods with 3/8 ARP bolts
Speed Pro L2268F30 forged pistons.35.5 cc dome.Top Moly ring.
Pete Jackson gear drive.(noisy).
Comp flat tappet mechanical with Crane full roller Energizer rockers.
.595 gross lift.248 @.050.110 lsa.
3919840 closed chamber rectangular port iron heads
2.250 intakes/1.88 exhaust valves
Dual springs with dampners and PC seals
New locks and retainers and competition grind
Polished Edelbrock Performer RPM dual plane
Hardcore 870 DP with quick change Dominator bowls,secondary jet extensions,screw in air bleeds,down leg boosters,4 corner mixture screws with a milled off choke horn atop a 1/2 phenolic spacer.
Moroso Aluminun short style water pump
MSD billet aluminun dizzy.Non vac type.
Proform polished cast aluminum valve covers
K&N 4 inch with drop base and x-treme air flow top plate
I will retain the ring gear,starter,alt and headers.
.030 over 427 BBC
Casting #3963512
Clevite 77,s
HV oil pump
