how do i hook up my reverse lights on my tubro 350? the lights where never hooked up and i dont see any wire hook up for it. if you have any info on this it would help out alot or if you have photos would help too. thanks
make model year? console or not?
A firstgen with a console has the switch on the floor shift assembly, inside the console. Wires are pink (power) and green (to the lights.)
The T350 itself does not have an internal reverse light switch.
Is your Neutral Safety switch funtional? As Jim stated, it's all in the N/S switch. Check the green wires to the reverse lights and make sure the are connected at the two connectors for the reverse lights in the trunk.
oh ok see i just put in a b&m mega shifter in my 72 camaro and hook up those wires and the light come on when i turn the key on when i am in park
