While I have been installing a new rear trunk pan and drop off panels etc....I was removing the original GM sealer between the inner wheel house and the shock tower panel. I found alot of rust under the sealer on the right hand side (passenger side) gap between theses two panels. Upon closer inspection, I found that the RH shock tower panel was rusted all the way through near where the shock mount is welded.....right where the sealer was laid in the gap between the shock tower panel and the inner wheel house....lots of rust.
I went and chipped away the GM sealer between the shock tower panel and the inner wheel house on the drivers side ......and there was no rust.
My question is, is this rust out more common on the right hand side (passenger's side) versus the left side (drivers side)?
