1 - 20 of 25 Posts
I'm interested to see this also. I installed a Ridetech 4 link with mini-tub and wondering what exhaust would fit
I'm turned down before the axle as well. I started to fabricate an over the axle exhaust, but I will be mini-tubbing in the fall and would have to rework the system again, so I put that project on hold. I'll probably buy some stainless mandrel bends once I tub it, and make some custom tail pipes.
FWIW, I mocked up the old tail pipes from before the 4 link, and they would have been routed right through the coilovers.
Keep in mind that Spintech makes ovals and transitions as well to get tucked into those tight spaces.
I have a set Stainless works used to make for a (now closed) vender. They work really well. Too bad they didn't keep making them. Most guys nowadays with the ridetech rear either turn down before the axle, run them under or have someone custom make them from scratch.
Discussion Starter #9
Thanks for the replys everyone. I was also thinking of having the exhaust exit on the sides in front of the rear tires
Discussion Starter #10
Stainless works replied with this part number.
CA676925CSAR
I looked it up and i cant tell if its over or under axle
Nice system, a bit pricey though
I'm mini tubbed and there is no way I'd get that through without notching the gas tank. I'd also love to see a side exit option.
Sent from my iPhone using Tapatalk
Discussion Starter #15
Tanksinc sells a notched tank
Pretty nice too
Also ridetech is supplying an upper bar tab jig to use to help locate the upper arm tabs on the rear axle
So since i want to get a new moser rear this jig will come in handy
I have a traditional 4-link set-up in mine with the Tanks notched tank. Will be getting to the exhaust probably next week. After much thought and contemplation, I've decided to exit in front of the rear tire with a 3-1/2" Oval and plan on doing a compound bologna cut to match the angle of the rocker. I also wanted to point out in doing some homework on exhaust that the "X" pipe will have a higher pitched ring to it while using a "H" pipe with have a much deeper throaty sound. I have heard both - youtube is a wonderful tool - and my personal preference by a long shot is the "H" pipe. Good Luck
Reactions: 68GK327
In one of the 48 hour Camaro videos, I seem to remember Bret saying you could order a Moser rear with all the Ridetech brackets already welded on. I'd definitely ask Moser about that.
Discussion Starter #19
Here's how I installed mine. I bought a 2.5" mandrel bent SS Magnaflow kit for an A body (because there were more pieces in it), and then I started chopping and fitting. My car is not mini tubbed, but I plan on doing that down the road eventually, so I kept all my left over pipe in case I needed to tweak the installation at that time. It looks awesome and I have absolutely no rubbing. The old saying is true, if you want it done right, you have to do it yourself! I don't know of any pre made kit that would fit with the 4 link, thats why I made my own.
1 - 20 of 25 Posts
