I have these heads that instead of having the double hump, they hace right angles. can someone exlain what this means? is it a high performance thing?
"Right angle" is mostly refering to the casting symbol on the ends of the heads. (looks like a ramp) Mine are "041" castings. Take valve cover off and check the numbers.
Right angle heads are known somewhat to be one of the better ones at the time for performance. Modern new design heads are much better.
If I remember right, 64cc chambers, small valves. Decent flow rates for a factory head.
Check here: http://www.mortec.com/castnum.htm
Scroll down to 3947041, 3947040, 3947041X SBC cyl head.
Hope that helps.....
Banned
Like this...
........./l
_____/.l_____
l___________l
And please spend some time here if you want to look into the MANY, MANY SBC heads..
http://www.chevytech.net/
Open it, hit on the pic of the head and use whichever list you want to get to the heads.
It's not complete, but all in all, it's got a bunch of good pic's and data.
pdq67
