1 - 19 of 19 Posts
I want to get a decent set of rims for my car but all I can ever find are 16" and I would like to stay with 15". I am looking for the crager 5 spoke (Torque 2 from crager). A freind of mine has a set of rally rims that are paintable but he said that they were from a comversion van. Are all Camaro's a 5 bolt 4 by 3/4 pattern or were there differences? Last but not least, I know its been asked a million times but what would be the largest 50 series tires that would fit without modification? Thanks in advance.
All Camaros came with 5 on 4 3/4 bolt pattern. The size tire you can fit will be determined by the offset of your rims and how high the car sits. Also how the rear end is centered in the car, will effect tire clearance.
Steve R.
i have a set of torque thrust D on my 69,
they help retain the classical look., and
they arnt all that bad, a tad heavy but
they look pretty nice... they are 15in rims
which is something you are looking for correct? you can get them up to a 15x10 which
is pretty good., unless your going to do
a major tub...
I am looking for the biggest tires I can stuff under the rear end without modification. If I put 15x10's on the back with 4 1/2" offset how wide a tire could I put on it. I want the Widest tire I can get. My friend said that I could get a 275r50 on the back without any rubbing. Would that take a 15x10 rim or could I use a 15x8 rim?
I had 265/50/15 when I first got my car and they rubbed all the time. The tires were mounted on 15x8.5 Centerlines with a 3.5 inch offset. I even had airshocks to jack the back up a little bit and they helped, but the tires rubbed everytime I pulled into the driveway.
[This message has been edited by gheatly (edited 02-22-2000).]
frank
A recent issue of chevy high performance had an article on how to measure your wheel well. As Steve said, every car is slightly different but the article will show you how to check yours. This will allow you to get the right tires the first time. I think it was the issue on sale now. If not, e-mail me and I'll look it up.
Rick Schaefer
72 El Camino
TPI 350/700r4
Gheatly
i saw in a recent issue of hot rod magazine where there is a kit of 7 pieces where you can put on to make your tires stop rubbing. I think it's just a manufacturers problem where if you put on any bigger tires than stock then they would rub. I'll try to find out all the info for ya and get back.
just put a set if BF goodrich ta on my 69 and i used a 255 65 15 on a 8 inch rally and 215 65 15 on front of it with 15x7 rally looks great
I just put a set of BF G TA 225R6015 all round. I had to file down one of the wheel well insert bolts to keep it from rubbing at the front. 68
I am currently running 255/60's in my rear mounted on 15x8 rally rims and I have no problem at all ... but you were asking about 50's. 255/60 is not that big but it fits and does not rub and I am sticking with them. I have "Big O" tire out here and they are more than happy to mount and trial fit any tire you want. Some will do it for free but they may charge you each time. I think it would be worth it in your case to get the look you want. Plus you can "really" see how much clearance you have when your car is up on the lift!!!
the biggest tire with a 4 1/2 backspaced 15" rim is a N50-15. This will put about 12 inches of tread on the ground per wheel. If you want pictures send me an email and I will try to send you some shots. This is without tubbing etc. The tire will be VERY close to the shock and will go all the way to the extreme edge of the lip flair of the fender. I test fit tonight a 30.5 by 11.5 slick on a 15 by 10 with 4 5/8 backspacing (Supertrick rim) and the extra size hit the inner fender and the shock.
My camaro is a 67 RS, with the 10 bolt posi and multi-leafs, I put 10x15 wheels with 295-50-15. That's 12" of rubber on the ground without air shocks, but my car rides high in the rear with the multi-leafs. I recently put a Ford 9", 2" narrower, same wheels and tires (custom ralley's) with both bolt patterns and 4 3/4 back spacing. With KYB gas shocks (very stiff), all of rubber is inside. I have a 1/2" of clearance between inner fender and tire. (Close
but no rub). Because of the multi-leafs, there is 2" between outer fender well and top of tire, that's why I don't rub. It doesn't look as bad as you would think, the car is NOT jacked up high in the rear. If any one would like to see pictures, please e-mail and I'll send photos.
Check out a set of Vintage 45 wheels from Vintage Wheel Works. They look just like the vintage Trans Am wheels that were used on the track. They are a 16 inch wheel and 16 inch wheels look great on 1st generation f-bodies. Its a stock look but with a flare of racing. I own a set of 48's for my 69 and I am very pleased with the quality and how light they are. Good Luck!
here is the link:
http://www.vintagewheelworks.com/Specs.html
I gather from all the responses of tire sizes that no one person really knows what will fit. 3 months ago I had N50-15's on the back end and they fit unless I went off-camber on an uphill approach that was steep. At the time I had a single leaf rear suspension. I now have a multi-leaf which is much stiffer and have 275/60's. My drag slicks are 15by10 Supertricks with 31 by 11.50's with a 4.5 offset. The N50's had a 12 inch footprint and the slicks have a 13 inch footprint and the 275/60's have a 10 inch footprint. The sectional density of course is all over the place. Therefore, an answer given on this board is suspect until you have actually measured your individual car. Any answer you get here may give you the range of the tires you may use but your cars actual measurements may allow a variance of a number of inches in height and width.
[This message has been edited by DOUG G (edited 04-09-2000).]
measure your wheel well,should be 11"x28.5",so a wheel of 9.5" or less will work a 10" hangs in the breeze,as far as a tire 275/60/15..with out mods is the biggest.and as for backspacing 4-4.5 is the max,also check for yourself or have a shop do it , if a tire is mounted you bought it,so measure twice and buy once.
<A HREF="http://www.hometown.aol.com/dagwould1/auto
Doug" TARGET=_blank>http://www.hometown.aol.com/dagwould1/auto
Doug</A> G.
68 Camaro
406 ci.
J
Guest
I had a 68 camaro and through trial and error I went through several different combos.I finally ended up with 275/50 on the rear.It is the widest tire I could fit under my car.If you turned into a steep drive sometimes it would rub on the inside wheelhouse.10s are allright if you run airshocks and are stuck in the seventies.275/60s fit fine also if you want a taller tire.8inch wheel with 4 inch backspacing.
1 - 19 of 19 Posts
