When I pull my 4 speed to overhaul it, was wondering if there was any real advantage to replacing the brass pilot bushing with a roller pilot bearing? Any disadvantages? Thanks.
john
If it ain't broke, fix it till it is.
The factory used the bronze bushing in cars and many trucks as it does the job very well. The bushing can be removed easily with grease and a wooden dowel. The bearing can not be removed that easily as you will need a different method. If you have any misalignment in your bellhousing the bearing will fail where the bushing is more tolerant of misalignment.
The bearing will not make your car any faster, it will not last longer or run better, so why use it at all?
Nobody knows. -Run the bushing!
-Mark.
I always use the roller.
GM now includes them with their crate motors, as do many aftermarket clutch suppliers.
In a precision application like my Richmond 6-speed, it's imperative.
All those hours spent dialing in the bellhousing alignment and then put in a soft bronze bushing?....nope.
I'd recommend using synthetic grease on the rollers.
A special tool is available to easily remove them too.
Don~ ZZ430DropTophttp://hometown.aol.com/zz430droptop67rs
~~~~and~~~~
70 RS
67 RS/SS Convertible, 70 RS
I put a new solid (I guess brass) in my 350 and I didn't notice how tight it was on the shaft until I had it together and it acted like I had no clutch at all. I was thinking about a roller (just to see if that was the problem) until I had several guys recommend against it. I pulled the original from my 6 cyl and put it in the 350. Works great.
My advice, it if fits good now, leave the old one in.
I am going against the grain on this one. I am not sure why GM, and Ford have decided to start using the roller bearings, as they usually will not spend an extra penny if not needed, but.....I know there are ten bazillion bronze ones out there with no problems, and I know how many of the roller ones I have seen turned to red "dust" like bad u-joints. If you really thing about it, the ONLY time the bearing actually gets used is when you have the clutch pushed in. At all other times, the input shaft is turning the same speed as the crank, unless the clutch is slipping. Personally, I would rather have the entire surface of the bronze bushing to support the input shaft, instead of just the 12 little needle bearings. I have never seen a bronze pilot bushing fail unless there was some drastic misalignment present betweent eh engine and trans.
Maybe someone from Gm who knows the true reason for the roller bearing will chime in ??
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
I agree with BillK.
When I bought my car the engine was on a stand and had a needle bearing pilot that was all messed up. It was a pain to get it out.
I put a bronze bearing in and have not had any trouble what so ever.
Kel
North Texas Camaro Club
Is the glass half empty or half full???.....Neither, the glass is twice as large as it needs to be!
Discussion Starter #8
Thanks for ll the input. Seems like the general consensus is bronze bushing. Guess I'll keep what I've got, save myself some aggravation and save a couple $ to boot. Life don't get much better!
john
I have the roller in mine, but I also aligned the bellhousing before using it. I have seen both kinds go bad and I can't tell you which one is really the best. I can say that when the bronze bushing goes bad it does less damage to the input shaft.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
