1 - 12 of 12 Posts
My freshly built 454 has the original GM rocker arms. Those rockers have 106,000+ miles on them. There is ONE that I cannot get to stop ticking and it is visually slightly off center of the valve top.
Comp "says" 15 to 30 more HP with their $139.00 Roller Rocker Arms. That sounds like a small price for "that much" improvement.
This is a Hyd flat tappet Comp 260
I guess I am asking.....
Is there really an advantage to roller rocker arms?
Full roller rockers would be better and any gain you would see would be from a more accurate ratio Vs. stock factory stamped steel (that aren't always accurate)
I love my roller tips!!!
I really don't think any of them give the increases that are claimed. Come on, 30 HP from a set of rockers? Ludicrous. There are certainly positives, but not close to that big.
I ran hundred dollar summit roller tips for years. They did thier job well.
Going with full rollers now, I'm sure they will do thier job too.
Full rollers are worth considerably more due to the way the fulcrum works versus the slipping ball of GM's, but I doubt you'll see 30hp. Do several searches before you decide on a brand, there are plenty out there that are good and plenty that are junk. On a budget, I think Harland Sharp is the best bang for the buck, they've been at it a long, long time.
I'm running a set of PROFORM full roller rockers and they only set me back $170. I was on a tight budget so that's why I went with those. You can clearly see the advantage of full rollers and compared to roller tip or stock. Go with a name brand for sure but I say your hp's will only go up about 10-12 not the 30 some people claim.
Don't want to steal this tread, but can you install rollers on a head without guides?
The HP robbing friction is in the ball and rocker pivot design. This is what robs power. By making this fulcrum a needle bearing design is what makes power. . .roller tips don't. If your not going to get full roller rockers then don't waste the money...what do I know. .. .I use to work for a rocker arm company.
Banned
6 hp??
I figure CC's investment cast Magnum roller tipped rockers b/c they are a uniform 1.72 ratio up to say their ABOUT 350 pounds limit are fine unless you use Ti/Nitride jobbers that increase the load to like 380 or so as a GUESS by me!!!!!
Go over what TiN treated stock type rockers can take and you need to use full roller fulcum and tipped jobbers imho b/c you will be up into the solid roller cam spring ranges that will need them to live!!
pdq67
I agree with Gary on the friction part of standard ball pivot . I had a set of Comp Magnums and I could see where the pivot pocket had "blued" a little at one time, not sure if it was at start up or not but they did get lube prior. But being I ran high spring pressures, that may have contributed to it. I have the full roller rocker now.
Marc, yes you can install these roller tip rockers on heads with no guides, you do have to use the "self-aligning " type. The have little guide tabs on the end of each roller to keep them centered on the valve stem.
1 - 12 of 12 Posts
