Ive decided to take my whole dash out. I see the courtesy light bracket, the speedometer warning bracket in the way of the light switch. My guess is I unscrew the bracket to the speed warning knob and that whole thing comes out with the dash. The light bracket isnt a problem I suppose either. For the rs light switch, I had advice to cut the hoses at about a foot and mark them. That sound like a good idea. Does anyone know how many wires or connectors are on the light switch? I cant see it well. Do I just yank off any connectors? Is it easy to get at to remove? One more thing. I noticed the speedometer cable has a clip on it. It looks odd. Does anyone have any tips on getting it off. I dont want to break it and never saw one like that before. I never took a dash off before, but I did get the pad off ok . If anyone knows about the little studs that screw into the dash pad to hold it in (They have the nuts on them you have to take off from inside), well, all of mine turned with the nut then stripped and turned in the plastic, so I had to use needle nose vice grips to hold the tip while i turned them with a tiny wrench. It took about an hour to do all of them. I am praying that was the worst part of this job lol
