Hi,
I have 69 camaro NON rs, but I installed the hideaway kit. Would like to install the rs headlights nozzle and i have the rs washer pump with the selonoid and i have the non rs waher pump with the motor. Should i buy different motor? Is the rs motor is different than the non rs?
Also i need the location for the washer bottle and how to mount it. I think it's in the passenger side if i am correct.
The only difference between the RS and non-RS wiper motor is the end plate with the stamped number and the two holes drilled in the base for the RS soleniod. The washer pump is the same, you just need the RS lines and addition "T"s/valves.
If you have factory Pass side inner fender, there will be 3 dimples near the battery for the mount :)
