I cannot figure out what gives with this pump/winsheild motor are the RS versions different and which wires go where?
Thanks,
Mike
Mike, the RS versions are the same as regular except for the RS washer selenoid screwed above the motor. There would be an extra wire harness pigtailed off of the washer wires to energize the RS washer when the reg washer is energized.
What is the problem with yours?
Kevin
Kevin,
My wires wont reach anyway I try it the ground seems to short which is odd since I removed it from there. Do you have any pics?
Thanks,
Mike
Here is a shot of mine.... my wiring harness was fried, so I made up a new one. The wires and plugs should actually be black...
Hope this helps....
McCorry,
yes that is exactally what I needed.
Thanks,
Mike
