I have an RS/SS 350 with A/C and am confused with how the vacuum lines are run off the manifold for both the A/C and Headlights.
In the Assembly Manual it has the headlight diagram with no mention that the line should hit the vac canister under the drivers fender to run the A/C. Should I "T" off the line and hit the canister which then goes to the A/C unit or do I need a different vacuum fitting on the manifold? I have a 2 vac line fitting with the brake booster line too.
Any help would be appreciated.
