I need to pull my intake and reseal, as the rubber front and rear ones extruded. I have seen suggestions on using just RTV on the end seals, and not to use the rubber ones. If I decide to use RTV, how long do I let it setup? I am also trying to cure coolant leaking up the "manifold to head" threads and pooling on the intake manifold. A pressure test last night validated the source, up the threads and around the bolt. It does not do this near the water outlets, but my guess is that is creeps up the bolt threads from the threaded hole in the head, which likely is open to the coolant passage. I'll use a different sealant there.
So 2 questions...
1. RTV cure time?
2. Coolant leaking up threads to pool on manifold...seen this before??
OH, and Happy New Year!
So 2 questions...
1. RTV cure time?
