Hi everyone
I filled up my tank and after a 15 minute drive around the neighborhood, I noticed some gas leaking under the tank when I got back into the garage. Upon further inspection, I can see gas on the outside of the rubber fuel line (between tank and line) on the lip of the tank.
Can I safely pull that rubber line off and replace it, or will fuel keep spilling out? I pulled the rubber hose on the line side and there was a strong flow of gas so I re-connected it. Any help, much appreciated!!
Thanks!
Some gas still in the line will leak out....won't empty tank, but wouldn't leave it disconnected over night either.
1969 Camaro RS
I suggest you open the gas cap as well before removing the rubber hose; this relieves the pressure from the gas tank.
