So with the outside temps rising into the low 30’s for the first time in many days if not weeks here in New Hampshire, I finally braved the cold of my garage and removed the drivers side valve cover to try and identify the cylinder heads on the 406 in my 69. They appear to be GM 14011034 - Bowtie, cast iron, 64cc chambers, 184cc port volume, angle plug, "Phase II" heads (photos below). I did some reading up on these heads and while they seem to have been a pretty good high performance head offered by The General some years ago, I’m a little bit disappointed as I feel they may be a bit small for the rest of the engine combination I have, but an engine designer I'm not so here I am asking for input.
The paperwork from the machine shop that freshened up the engine just before I purchased the car indicates the camshaft is a flat hydraulic Engine Pro MC1996 .509/.509 lift, 246/246 duration @ .050, advertised duration of .306/.306, lobe separation of 106/112 and rpm range of 3,200 to 7,000 rpm. The current intake manifold is an Edelbrock Bowtie II Victor Jr. and my plans are to replace it with an Edelbrock RPM Air Gap over winter. Looking for thoughts on what I have, I know the cam isn’t a good option for the street which is where this car will spend most of it’s time with an occasional trip to the strip. Should I be considering cylinder heads as well or run with these?
The rocker arms are 1.5 aluminum roller rockers, but no identification on them that I can find (photos below). Does anyone have any ideas what they are from the photos?
Thanks in advance, Scott
