I found a 80-84 sbc 350 motor, it's a 4bolt main with the block casting number of 14010207. How good is this block? Going to rebuild so heads and other parts not important.
I believe that is not a 1 piece RMS block if that matters to you
like any used block, if machine shop says it can be rebuilt (magnaflux & mic) it otherwise should be fine. Generally non rebuilt blocks need a .030 overbore
Nothing wrong with the blocks from the 80's. I think the one piece rear main seal started mid 86. As long as it checks out as already mentioned, I wouldn't shy away from it. 👍
