1 - 2 of 2 Posts
I have the following engine and I'm not sure what spark plug suffix to use on my car:
Motor: 350 Block (with dished pistons)
Heads: 333882 (76 CC)
Intake: Eldelbrock Performer
Carburetor: 600 cfm Holley
Distributor : Stock with Crane XR-i Electronic Module
Coil : Accel Super Street P/N 8140
Spark Plug Wire: Replacement AC Delco
Currently I' using: AC R45TS
My questions are:
1) I believe that I should be using R44 instead of an R45 type,
which one should I use and does it make a difference.
2) Which suffix should I use, is it "TS"?
3) Does my 333882 heads required Spar Plugs of a different type (suffix) than used on the original 1969 Camel Hump Heads?
Thanks,
Daniel.
1 - 2 of 2 Posts
