Pull driveshaft (plug rear main shaft opening on transmission)What is all involved here?
You're a better man than I am if you can install a scattershield with the motor in the car. If I rememer correctly, there are about 20-30 bolts. Mine is so tight with the firewall I couldn't possibly do it with the motor in the car. I agree with Christopher, pulling the motor is the only way to go. IMO. Mike. :beers: :beers:Pull driveshaft (plug rear main shaft opening on transmission)
Pull shifter (and anything needed to get to the shifter)
Disconnect wiring/speedomter cable to transmission
Pull transmission
Pull clutch linkage to extent necessary
Pull old bellhousing
If installing motor plate (and why wouldn't you?), pull clutch/flywheel
Install new scattershield - check alignment
Correct alignment of scattershield following manufacturer's instructions
Install motorplate, flywheel, clutch (align clutch), scattershield, clutch linkage, transmission, shifter and driveshaft.
This is a rough list, as you didn't specify the model or year of car. You may also need to drop the exhaust system, remove a header or do other things to get adquate room to work.
Not too bad with a lift; tough job laying on your back!
One word: lift. Did it with the engine in the car on the lift.You're a better man than I am if you can install a scattershield with the motor in the car. If I rememer correctly, there are about 20-30 bolts. Mine is so tight with the firewall I couldn't possibly do it with the motor in the car. I agree with Christopher, pulling the motor is the only way to go. IMO. Mike. :beers: :beers:
My statement was "if I remember correctly", obviously I didn't remember correctly, there are only 18. Please refer to page 197 of the new Summit catalogue for a picture. And thanks for correcting me. Mike.20 to 30 bolts? There is not that many holes in the block.
Seven (IIRC) in the block and then the bolts for the block plate.20 to 30 bolts? There is not that many holes in the block.
