The tensioner seems strong enough. New belt doesn't help. Can visually see that the tensioner pulley is not in perfect line with the other pulleys so the belt edge rides forward a bit close to the rounded edge of the front of the pulley instead of centered on the pulley. Is this common? Belt comes off if you hit the brakes hard or run over a large puddle and some times it seems for no reason. Chrysler had a similar problem with their Caravans and Gates came up with a different pulley that had a raised edge so the belt wouldn't slip off.
Anyone else have this problem? Fixes?
