What is the procedure for setting intial lash on hydrolic setup. I put in a new cam and lifters along with new crane roller rockers and the books I have don't tell me how to do it with hydrolic lifters. It is a 68 with a 327. Your help would be appreciated. Thank you
The night-time is the right time
****James Bondo****
Cars:'68 Camaro RS, '73 Porsche 914, '69 Datsun 510
www.whosnextracing.com
Hey sureguy. First you have to find TDC. Start on your # 1 cylinder, and start rotating the pushrod with your fingers. Tighten down the nut until the pushrod justs stops. This is zero lash. Now you have to decide how much preload you want to put on the lifter. I would suggest a half turn. Now just turn the engine 90 degrees and proceed to the next cylinder. With this method you'll be at TDC on every cylinder. The firing order is 1,8,4,3,6,5,7,2. Remember the engine will reach TDC ( top dead center) twice. Once for the compression stroke, and once for the exhaust stroke. To make sure your on the compression stroke, it's a little bit trickier when you don't have any other components on the car. I have noticed that when I'm on the exhaust stroke most all of my pushrods will be pritty even on the 1,3,5,7 bank, yet when I'm on the compression stroke, cylinders three and five will have pushrods that are noticably at different heights. I would suggest buying some degree tape to put on the harmonic balancer to help you find every 90 degrees. Also make sure you are turning the engine clockwise ( from the front of the engine). Hope this helps
Also, If you pull the spark plug and put your finger over the hole on #1, you will feel pressure as the piston comes up on the compression stroke...
Discussion Starter · #4 ·
Cool Thanks, they should really put that in the books!
****James Bondo****
the best way to tell where the lifter is on the cam: as soon as the intake valve closes, the exhaust valve is on the base circle of the cam; as soon as the exhaust valve opens the intake valve is on the base circle of the cam. the base circle or heel of the cam is the lowest point the lifter will ever be on the cam. the valve lash depends on you cam and spring combo. My grandfather taught me to set valves while the engine was running. One valve at a time, loosen the rocker nut until you hear the lifter "tap." slowly tighten the nut down to just silence the tap, then go 1/4 to 1/2 more rotation with the wrench. Papa used to say tighter for tourqe and looser (1/4 turn) for higher rpm power. this is not the safest way because of oil splash and the risk of fire. I have been using it for a while on street machine, mine and friends. it seems to work very well. be careful and good luck.
josh
