1 - 10 of 10 Posts
I am trying to set up a hydraulic roller cam. I am trying to determine the correct push rod length but don't know how to deal with the hydraulic lifter collapsing. I am using light springs but they still collapse the lifter a little. How do you set up a hydraulic roller cam? How do you deal with the lifter collapsing and changing the lift and the length of push rod needed?
I could really use some help with this. I have heard that you need to put the lifter in oil and pump it. Did that but it didn't help.
Matt
Are you using the 'magic marker on the valve stem' method? I helped a guy do this once by using no springs and just holding the retainer up against the rocker while the other guy rolled the motor over with a breaker bar. Maybe you just need a lighter checking spring?
Thanks Mark,
I am using the magic market method. I am not getting much of a witness of where the roller tip is riding. I though of using a lighter spring but that would leave even less a mark. Also, I would think that the lifter does need to collapse a little in order to work. I just don't know how much.
Matt
Lifter should be collapsed 0.020'-0.050" for proper pre-load under operating conditions.
Use a lighter spring and use SOFT DYKEM (Hi-Spot) on the roller part of the rocker should leave a mark on the valve.
Add 0.025" when you get your measurement
do you have a soild lifter you can borrow? That's really what you need here.
lifter may bleed off by turning over motor --try lipstick on stem -makes it easier
I like lipstick on my stems! you should be able to soak the lifter in oil and manually pump it up so its not an issue :yes:
You need to use a solid lifter to do this. I have one that you can borrow if you promise to return it(wasn't real cheap). You can use a sharpie, or machinists dye on the valve stem tip. PM me. Mine is for the retrofit type lifters, not stock like later model factory equipped roller cam engines.
1 - 10 of 10 Posts
