I've read that rear shackel bolt torque is 40 - 60 lbs., but is that for the top and bottom bolt?
I wonder since I assume the shackel has to pivot back & forth, so wouldn't that much torque keep it from moving with spring tension?
Thanks.
Re: Shackel bolt torque?
Doug, the shackle nut is bottoming out on shank of the bolt (with the shackle metal in-between), not the rubber. The length of the bolt shank is what is providing the clearance for the rubber. like Joe says, lube the shank where the rubber rides. Luck!
