1 - 2 of 2 Posts
I have a 89 rs 2.8.its pretty biffy to others but getting slow to me. How hard is it to put a shift kit in. And will that make a difference. thanks kevin.
you probably have the TH350 or an early TH700 (not the R4) and I woudlnt recomend it. take it to a trans shop as a shift kit involves drilling into the valvebody to insert check springs and balls to give it a harder gear barking shift. you can try it yourself, but you better try it on a Junkyard valve body so you have a "just in case" recovery.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING! http://nav.webring.yahoo.com/hub?ring=camaronet&list
[This message has been edited by Chris Edwards (edited 01-02-2001).]
1 - 2 of 2 Posts
