Hi, I bought a Ponti-Action bolt in drive shaft loop and it mounts between the trans cross member and the trans mount. This raises the trans by a 1/4 inch and I would rather avoid that. I was wondering if there was a trans mount out there that was made a little shorter? If the mount was smaller it would offset the extra height from the loop.
Any parts guys out there seen a shorter trans mount?
Is this quarter inch so meaningless I should not worry?
This is for a 68 camaro with a 350 trans.
http://gallery.bcentral.com/GID4716...4-speed-PG-Turbo-350-long-tail-Turbo-400.aspx
Thanks,
James.
Thanks,
James.
