1 - 2 of 2 Posts
I'm working on a '67 with a bbc.
I decieded to get this radiator, http://store.summitracing.com/partd...4294908198+4294925084+400304+115&autoview=sku
It bolted in just fine. I also purchased a reproduction fan shroud for a '67 with a BBC, but the opening for the fan is to far offset to the passenger side. The hole in the top of the shroud for the mounting bracket is about 3" to far to the pass side, as compared to the holes in the core support.
Would a small block style shroud work? Thanks
The radiator is for a sbc so it should make sense that it would need a sbc shroud.
1 - 2 of 2 Posts
