I just replaced all of the wiring in my '68 Camaro. Front parking lights, side marker's and rear parking lights won't work. Flasher's turn on, but won't flash. I have all new bulbs and new 2 prong flasher in fuse box. What did I miss? Front/Rear turn signals work and brake lights work. Also, the opposite brake light goes out as well when the other turn signal goes on. I don't know where to go from here.
Thanks in advance!
Jeff
[This message has been edited by BelgianSS (edited 08-01-2002).]
Try checking all your electrical connections. It may just be a bad connection somewhere.
What did you replace all the wiring with? Was this all Factory Fit, or Painless? Some of the wiring harnesses come with way too much dielectric grease. This creates all kinds of shorts, not to mention the massive nightmares trying to figure it out.
I used Factory Fit wiring. I'll check the amount of grease and clean as necessary.
Thanks!
