Can anyone help me make a decision here? I'm looking at the Competition Engineering solid bushings (aluminun body and leaf springs) at half the cost of the Global West pieces. I know you get what you pay for, but here are my thoughts:
Interlocking bushings for the body should not be required-I can see why they are needed in rubber/poly applications for absorbing up and down movement of the subframe in relation to the body which won't happen with solid bushings.....
As long as a large washer is used under the bolt head, the CE design seems that it should work fine AND they register in the s/f mounting hole so that's not an issue
I know the Global West leaf bushings come with Delrin inserts and shackles, but I can re-use my shackles and there is a local plastics company that carries Delrin so I could add that myself if it turns out to be needed. What difference will it make that the GW units are anodized?
In a nutshell, I want quality at a decent price ! Like I said, I know you get what you pay for but spending more doesn't necessarily mean you're getting something better. Let me hear some thoughts......
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
Bret Copsey
'92 Caprice wagon
'98 Malibu
