After reading through lots of discussions in the archives on replacing with a-arm tubular kits vs rebuilding my front suspension I decided on rebuilding using the existing control arms, delrin bushings, proforged ball joints, including the .5" taller top ball joint, Eaton springs and Bilstein shocks. However, I just got the lower arm out and it looks like this:
Someone clearly enlarged the lower spring pocket and I suspect it was to fit in the giant 'Bruiser Gas XD' shocks that came out:
It seems unwise to put these lower arms back in. But if it's really not a problem let me know.
If I have to buy new lower arms anyway, is it worth backtracking and reconsidering a full tubular kit? Is picking up just tubular lowers a good idea? Is there a good source of quality stamped steel arms?
Thanks for any advice or recommendations. If there are brands of a-arms to avoid that would be good to know too.
Kris
Kris
