for starters no the frame horns shoudl be the same hight. otherwise the fenders will not fit amung other things . as far as the distance between the frame and the body that could be the frame mounting point could be bent causing the frame horn to be up on that side. i would look at the mounting points on the car and the subframe to be sure that the are all the same. if the sub frame is bent then do not try to repair, it is a replace only because it is the foundation of the car. it is like a house. it is only as good as the foundation. trust me on this i have been in the coillsion repair bus. for over 30 yrs. and did nothing but major hits for 15 of those years. my advise is if the car is movable have a local frame shop look at it of have a frame tech. come over and look. there might be other damage that you don't see that need to be repaired. good luck
