1 - 14 of 14 Posts
Hi guys, I don't no how to post a craigslist listing but there is a space saver tire for a 69 SS camaro on charlotte NC craigslist. Not sure if it is still available or correct tire for 69 Camaro but thought someone might be looking for one.
Dennis, have you tried the CRG site? I seem to remember a discussion over there at one time on this topic. If you can snag one, they sure are nice for the xtra room in the trunk.
cat
I did look there it shows how many where made but nothing on stampings or maybe I missed something? :clonk:
It seem like since there where so few built the info is scarce.
Info on this is scarce. Just did a quick search, and there is a fair bit of info... esp on the 2nd page of our own archives. Looks like there were some who tried to get to the bottom of this, and you might want to look back and contact them to see if they ever came up with something definitive.
capt
:confused: Where do you find info on space savers? :confused:
Not really to much out there or to 'know' for that matter.
The rim usage is the same for the other types used on a particular vehicle if the RPO was available on that model.
S0 - if the car application called for an "XA" rim, then the Space-saver rim was an XA and the Goodyear sourced collapsible tire was mounted to it and placed in trunk.
If the Space-saver tire was used-up or damaged in future years while being used, the owner could have a standard design tire remounted on the rim for use as a spare and it would/could match the other tires installed on the vehicle. All sorta makes sense if you think about it ...
The dating on the rim should match up closely to the others originally installed on the car as far as dates.
The tires were date-coded also and would be in-line with the common dating of factory installed options, with a few maybe falling 'outside' - towards the earlier side of normal, as is common for some lower ordered options.
Hopefully Kurt or one of the other CRG guys will see this and correct me on anthing I missed or add to the info. Maybe even provide a direct link to some of the CRG info ...
John
The use of a 'space saver' spare makes a lot of sense for a car being *used* for the extra room made available in the trunk, but for a 'date matching' (down to the tires) show car.. I doubt very much that 'extra trunk space' is a big deal.. :)
For the show car, you're right, but for a reg car #'s matching with a woofer in the back, wanting to pack a lunch cooler, folding chairs, some cleaning effects, small tool box and a small suitcase for away meets...the extra room is just enough to bring all that about. I just hate to pack things in the back seat. I couldn't do it without the space saver. But each to his/her own.
capt
Hey Capt I looked through the old treads in the archives the threads seam to repeat this tread questions with no definitive answers there are plenty of assumptions which some make sense, some don't.
I have two space savers that I removed from very original cars both where 68's both were from Firebirds. Neither of which have any 2 letter codes. :confused: Both are gray in color one Has never hit the road the other maybe once. I thought maybe Firebird & Camaro could be the same but I don't know for sure. I was thinking if you have a real deal for sure space saver in your car, or anyone else who does would post some pictures of the markings, who knows maybe we could figure something out? :thumbsup: I will take some pictures of the ones I have and post them soon.
Ya Den, I found the same thing with the posts re. the space saver. Guess that's yet another topic for the gurus to attack on CRG. There might be a few who have delved into the Camaro for some time like Dalglish (sp?), Bob Harris from Camaro Specialties (NY), David from David T's (Edmonton, AB), and some of the guys at D&R (IL) who deal with parts on a day to day basis who might have some answers.
capt
So... did you find some pics. I seem to remember pulling a space saver out of an old Camaro (perhaps just another GM car) at the junk yard in early seventies. I know I still have the tire, but not sure about the rim. I am sure it was as you describe, gray.
I did take the pictures but got side tracked on downloading them but here's what I have, Anyone else have any for sure originals?
1 - 14 of 14 Posts
