Hi guys
I have an issue with my 350 and wanted to run them by you here. I have to say the small block is not in a Camaro though . it is out of one.
But this seemed to me to be the best place to help me.
I noticed the other day that the white part of my plugs are turning almost black. what does that indicate or is that normal.
thanks
Al :)
Sorry my bad , I mean the white on the outside of the plug. :( but thanks because I am going to sit down and try to explain the problem I am having that started with a miss in my old motor to checking and replacing everything on it to finally installing a new motor and ending up with the same miss . it is not as noticable at idle but under normal driving conditons it is. it is constant and seems to get worse as you drive. that is the basics . later I will explain in detail.
Almost gave the car away last summer !
thanks
Al :)
The discolor of the porclein is due to ionization of the air around the plug due to the high voltage traveling within the plug. Normal occurrence. Simular to static electricity - hair and carpet thing.
