Just got this 94 lt1 camaro its sputtering. And popping when I give it gas previous owner smashed the egr line closed could it be the problem?
I doubt it. EGR comes into play when the engine is warm and cruising.
My first question would be "are there any codes set"?
Most likely the Optispark is bad and water pump probably leaking on it just a little
+1. This can also cause intermittent backfiring and won't throw a code. If it is this, make sure you update your optispark to the one with vacuum. I can't remember if 94 is when they started that or not. My 93 didn't have it.
