yup, they just slide off,m tho they can get kinda stuck on there. Use some good penetrsating oil as suggested. screw the nut on a few turns, support the squirrel cage, and whack (gently) on the nut, she should drop off.
Be careful, that squirrel cage ain't too strong, easy to trash it.
Use penetrating oil and a flat blade screwdriver in between the cage and the motor. Gently turn the screwdriver and it will loosen the cage off the shaft.
Thanks guys, got it off this morning. :thumbsup:
I am taking it off because it needs to be replaced. Looks like a little critter had its' way with it for quite a while. :(
Anyone know where to buy just the cage?
Phil
Classic or National should have them.
