do you gain any clearance with an ss hood verses a flat hood.
will a big block with a performer rpm intake and holly carb fit under an ss hood?
I am not sure if you gain any clearance between the two hoods but, I have a 68 with a SS hood,396,edelbrock performer intake, and holley 750 and no clearance problems. The hood insulation does rub the air cleaner. I hope this helps Erik
Discussion Starter · #3 ·
do you have the bb frame mounts?
i am still using the sb mounts.
if the motor sits any lower though the headers wont fit and the crank pulley will hit the frame.
