How can you tell for sure on a 69 camaro if it is an ss. There is no x code on the tag. Can you send the vin anywhere to find out.
If it's an early production '69, there's no X code on the cowl tag. From what I've been told, there should be 2 fuels lines running from the fuel pump, 12 bolt rearend and front disc brakes.
Well yes two fuel lines unless it is a L/78 big block car then it would have 1. It must have front disc brakes. Do you have the VIN that might help. LA cars will not have the X-code. what motor is in the vehicle? 350 or 396 was only two options. we can de-code engines for you if you have that info. what more can yu tell us?
1969 RS Z28 Black, white deluxe interior,
http://www.corvetteforum.net/c3/corvettj
