I have a remote mount solenoid and this only happens when the battery seems low on charge. I can start the car but the starter keeps going and I have to pull neg terminal to make it stop. One ground wire at fusible link was actually smoking last time this happened. I have run the car at least 50 times with this remote solenoid and it has only done this 2 times. Any chance this has something to do with the battery going bad???? Any ideas?
yes you almost figured it out your self.
low voltage to the starter selonoid will raise the current.this in turn can melt the selonoid contacts together resulting in a contunios running starter.
